Si B’s 1/35 Zvezda T34-76 Mod 1943 Uralmash
  • Si Benson
    • 3572
    #211
    I hope your UM is better than the one I am doing at the moment:sad-face:
    [ATTACH alt="41JTSl7QBlL._AC_UL600_SR600,600_.jpg"]416704[/ATTACH]
    Hmmm me too! Are you tweaking the bejesus out of it?
    • David Lovell
      • 2186
      #212
      [ATTACH]416704[/ATTACH]
      Sorry Si, come on now Steve great subject choice , you should know better than to expect a shake and bake ,im sure Si will back me up most of them are great little kits you just have to sit down chill and work through them you get a lot more self satisfaction with the end product than building S+B no brainers. Only a leg pull? I look at them as I've only got a ten pound box of problems not wasted thirty or forty quid on something that needs another sixty quids worth of metal tracks and photo etch .
      I would insert some of thoes smiley winking face thumb up things at this point but don't know how.
      Si well done once again fantastic stuff have been inspired all the way through with this build.
      Steve dont you dare diss my beloved tru scale(72nd) pull your socks up and crack on no one likes a winger(or in Harry's case a ginger)once again smiley winker thumbs up hearts . Dave
      • Isitme
        • Nov 2020
        • 795
        #213
        Si,
        Now that is brilliant.
        Mike.
        • Si Benson
          • 3572
          #214
          Cheers Mike, much appreciated :smiling4:
          Well I think I’ve finished for this one. Scratched a couple of ammo crates and made some tarps using VMS paper shaper. Some ropes made from ship rigging and then painted up....
          I’ll do some more pictures in the light of day tomorrow...:smiling4:
          • Fernando N
            • 2448
            #215
            Very nice Si, looking forward to those pics :thumb2: :thumb2:
            • adt70hk
              • Sep 2019
              • 10446
              #216
              [ATTACH=CONFIG]n1147769[/ATTACH]
              Very good Si. That really has turned out nicely.
              How do you find the paper shaper? I've seen night shift use it I've and found it an intriguing idea.
              ATB.
              ATB.
              • Si Benson
                • 3572
                #217
                Thanks Fernando, I took a round of pictures this morning but they haven’t come out too well and I see I’ve missed out the glass from the light, I’ll try again later :smiling5:
                ATB.
                ATB.
                Cheers Andrew,
                The VMS paper shaper is good stuff and easy enough to use. I found it a lot easier than rolling green stuff or milliput type stuff.
                I used the VMS paper this time which is quite thin, I’d like to try some thicker paper next time and put more creases and folds in.
                  • 15827
                  Hi Si
                  That is very good indeed. One to be proud of. The simple base sets it off a treat. That VMS paper stuff looks to work well.
                  As for UM Kits - I did that SU-100 for the Simon T GB. Not too bad - cheap and cheerful perhaps best described it. I'm sure you'll raise yours to another level.
                  • Si Benson
                    • 3572
                    #219
                    Originally posted by Jim R
                    Hi Si
                    Cheers Jim, very much appreciated :smiling4: Ive built a couple of UM kits and they do seem to benefit with a few tweaks.
                    This morning I painted the inside of the light with silver and then fitted the lens, I then gave it all a light coat of matt.
                    And now then chaps, I’m calling this one done....finally!
                    I took some pics with both natural light and some under my desk light.
                    Sorry for the quantity :flushed:....Click image for larger version
ID:	1147885Click image for larger version
ID:	1147886Click image for larger version
ID:	1147887Click image for larger version
ID:	1147888Click image for larger version
ID:	1147889Click image for larger version
ID:	1147890Click image for larger version
ID:	1147891Click image for larger version
ID:	1147892Click image for larger version
ID:	1147893Click image for larger version
ID:	1147894Click image for larger version
ID:	1147895Click image for larger version
ID:	1147896Click image for larger version
ID:	1147897Click image for larger version
                    Really enjoyed this venture into ruskie stuff, a pleasant change from grey or dark yellow :smiling5:
                    Thank you for all the kind words of encouragement along the way, it has been greatly received :thumb2:
                    cheers
                    Si B
                    • BattleshipBob
                      • 6828
                      • Bob
                      • Cardiff
                      #220
                      Change from grey and yellows, you have been got at by mr Race:dizzy:
                      Thats a superb build Si, most impressive!!
                        • 18959
                        That is excellent Si. Really nice finish on a fine build.
                        • adt70hk
                          • Sep 2019
                          • 10446
                          #222
                          Very, very nicely done Si.
                          A very nice job indeed.
                          • langy71
                            • 1957
                            • Chris
                            • Nottingham
                            #223
                            Absolutely beautiful build Si, top notch indeed.. it looks soo realistic. :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: :thumb2: :thumb2:
                            • Steve Jones
                              • 6615
                              #224
                              Fantastic final pictures. Really shows up well the modulation work. Lovely final detailing and base. As you say its a nice break from the normal builds. One of your best Comrade
                                • 15827
                                Hi Si
                                Agree with the others - excellent.
