Modellers vice build
  • Mr Bowcat
    SMF Supporter
    • Dec 2016
    • 4692
    • Bob
    • London
    Morning all.
    This is not a model, but a modelling adjacent tool.
    I recently became aware of the Dspiae vice. Although I have no need or want of such a tool, I did appreciate the engineering behind it and decided to build my own version and thought it might make an interesting blog.
    This is mostly made from metal from my scrap bin, the only new metal I bought was some 30x30mm EN1A for the main body.
    Before starting the build I wanted to have a practice of the ball joint mechanism as this seemed the most complicated. I used a scrap of aluminium and based on this changed some of the dimensions, including the diameter of the ball.
    The build started with the base. This was made from two parts, some 5mm steel plate recovered from an old office chair, and some 10mm aluminium left over from a previous build.
    The ali plate was brought to dimension first and a hole pattern drilled and counter-bored. Then the steel plate was brought to dimension, the same hole patter drilled, but this time the holes were tapped for M4. Finally, with the plates bolted together, a 8.5mm hole was drilled and tapped for M10 to take the stud that will have the ball rod fitted. The ali plate is only there to give additional thickness for this thread, 15mm instead of 5mm if just the steel plate was used.
    The stud was then turned and knurled on the lathe and an M6 hole drilled and tapped for the ball rod. The stud is just to give the rod some extra support. The rod itself is just a length of 6mm silver steel with a 12 mm ball at one end.
    Once assembled, that was the base finished.
    Next I made a start on the main event, the vice jaws. As mentioned I had bought some 30x30 EN1A for this part, a chunk was cut off and the ends squared and brought down to 40mm. A 5mm hole was drilled all the way though, and half of it tapped M6. The part was then flipped in the vice and the hoe opened up to 8.5mm to the half way point.
    The last operation on this end was to drill the 12mm hole for the ball, and mill a 7mm slot. All edges were chamfered to eliminate sharp edges.
    After that I just need to turn up a quick thumb screw which is used to lock the vice in position.​
    And that's as far as I got this weekend. At the moment the vice is just a block of steel, however the ball joint works exactly as planned. The chamfer on the underside allows a nice range of motion, and the slot allows the vice to be turned 90 degrees to horizontal.
    That's it for now, will post more if there is interest.
    Si vis pacem, para bellum.
  • AlexBB
    • Feb 2022
    • 51
    Nice Work there Bob,
    Will be interested to see how this turns out..
    AlexBB
    • pjgtech
      • Dec 2023
      • 1315
      • Peter
      • Swale Kent UK
      Very cool, would luv to see the rest of this build. Although I am quite handy at most general building/DIY stuff (ex plumber and retired surveyor) I really wish I had the knowledge and skills to do stuff like this. Fantastic work.... 8-)
      • Mr Bowcat
        SMF Supporter
        • Dec 2016
        • 4692
        • Bob
        • London
        Cheers gents.
          • 16173
          That is so good. Well designed and engineered. Very clever. Probably better than similar commercially made ones and I'm sure a great deal cheaper.
          • dave
            • Nov 2012
            • 1844
            • Brussels
            Interesting build
            • Richard48
              • 2176
              • Richard
              • Clacton on Sea
              Bob that is some serious machining there.Mightily impressive indeed.Hats off to you.
              • Mr Bowcat
                SMF Supporter
                • Dec 2016
                • 4692
                • Bob
                • London
                Cheers all.
                Did a little bit on this yesterday. I don't like to run the machines too late in the evening out of respect to my neighbours.
                The surface is perfectly smooth despite the tooling marks, though I may run some sandpaper over it jut to give at a more aesthetic finish.
                • Mr Bowcat
                  SMF Supporter
                  • Dec 2016
                  • 4692
                  • Bob
                  • London
                  A very good Friday morning all.
                  A little more progress, the moving jaw. This was cut (by hand, very good exercise) from the 30x30 bar and faced so it was parallel, and a small chamfer added. This is to allow it to close flush with the fixed jaw as all endmills have a radius, so leave a slight fillet in the corner.
                  Obviously it's way too tall, so it was roughed down to within .5mm, then the two parts flycut together to get a perfectly even top surface.
                  Which now leaves this, ready for the next operations.
                    • 16173
                    Very interesting to see this coming together.
                    • Mr Bowcat
                      SMF Supporter
                      • Dec 2016
                      • 4692
                      • Bob
                      • London
                      Another couple of parts completed, the leadscrew and leadscrew thumb screw.
                      Both were very satisfying to make and involved several operations, and I'm pleased that I nailed the dimensions.
                      • flyjoe180
                        • Jan 2012
                        • 12944
                        • Joe
                        • Earth
                        This is very impressive craftsmanship Bob
                          • 16173
                          Better and better. All looking so neat and sorted.
                          • Mr Bowcat
                            SMF Supporter
                            • Dec 2016
                            • 4692
                            • Bob
                            • London
                            Cheers gents, it's been a fun little project so far.
                            • Mr Bowcat
                              SMF Supporter
                              • Dec 2016
                              • 4692
                              • Bob
                              • London
                              I did a little more on this yesterday evening.
                              The original design appeared to only use the tensions of the spring to keep the leadscrew in place. I wasn’t completely happy with this design as vices generally have the leadscrew retained in the fixed jaw. After a bit of thinking I came up with a simple design.
                              The lead screw has a portion near the thumb screw that is 7mm diameter, and goes into the 7mm hole in the fixed jaw. However I had turned a rebate 2mm deep and 3mm wide in this section.
                              I made up a brass pin. This is 10mm long, 4.1mm diameter, and has a 5mm diameter semicircle milled in one end.
                              I then drilled a 4.2mm hole from the underside of the fixed jaw which was tapped M5 just over half way down. This hole intersects the hole previously drilled for the leadscrew. This was for the brass pin that you can just about see in the pic. I had filed a small notch in the pin so I could orientate it.
                              Effectively with the lead screw installed the brass pin locates in the notch and is held in place with a M5 grub screw. This retains the leadscrew in place. The brass will not gall the leadscrew as it wears, and can be tightened to remove any play. I will still use the spring as I have already milled the features for it.
