Andy's 1/72 Revell Topol
Andy T
Sheffield
For this GB I'm building the Revell boxing of the RT-2PM Topol (SS-25 Sickle), to give it its full, Sunday name, in 1/72.
Originally by Zvezda I thought this version would have more legible instructions, and it also includes the 3 tone camo scheme I'm probably going to finish it in.
Click image for larger version  Name:	PXL_20240928_143852573.jpg Views:	33 Size:	512.8 KB ID:	1234089
Click image for larger version  Name:	PXL_20240928_143919426.jpg Views:	26 Size:	648.4 KB ID:	1234090
There are 309 parts in the box (apparently) but a lot are duplicates for the very detailed suspension system, depending on whether I pose it in launch or transport mode
Click image for larger version  Name:	PXL_20240928_144057620.jpg Views:	26 Size:	555.0 KB ID:	1234091
Click image for larger version  Name:	PXL_20240928_144118791.jpg Views:	26 Size:	475.6 KB ID:	1234092
Click image for larger version  Name:	PXL_20240928_144157804.jpg Views:	26 Size:	482.2 KB ID:	1234093
Click image for larger version  Name:	PXL_20240928_144333798.jpg Views:	26 Size:	472.1 KB ID:	1234094
I'd prefer to build it in launch mode, but given the size of the missile I'll struggle to find shelf space, so we'll see. I'll have to decide early in the build though
Click image for larger version  Name:	PXL_20240928_144415418.jpg Views:	26 Size:	483.9 KB ID:	1234095
See you at the start. Not long now :)
Yes, I can see me needing my strongest glasses (and a lot of patience) for cleaning them all up.
Most parts seem intact at the moment, with just the missile nose cone having broken free from the sprue.
Thanks guys.
I have made a start on this, honest guv, but I still haven't got the basic chassis together and I'm already 41 fiddly parts deep! I've built full kits with less than that 😂
Due to the small size I'm going to follow the instructions lead and paint inside the chassis before assembly. I doubt I'd manage it later, short of dunking it in a pot of paint.
Click image for larger version  Name:	PXL_20241004_175444812~2.jpg Views:	0 Size:	341.7 KB ID:	1235272
I have to add - it's showing it's origins as a Zvezda rebox, with incredible detail & fit, but silly errors in the instructions.
Thanks guys.
I've painted & assembled the chassis now. With so many different parts to line up it was a bit of a wrestle but I can now move on to the suspension assemblies while it dries.
Thanks Si.
I've started assembling the suspension & drive train. Turns out it's a 14x12, with the middle axle steerable, but not driven.
With so many almost identical parts I've sorted out a filing system. This all still needs some cleanup but I prefer to do the seams, sprue nubs and glue joints at the same time where I can
You look to have made good progress, well organised. Seams on rounded parts are always time consuming and awkward.
That's a lot of wheels. Like doing a tank only no tracks. Looks a fine model though.
Great work Andy. With all those small bits lying around I would try not to sneeze until they are attached.
You are off to a good start. I like your parts organization solution, I can see where that would be beneficial when there are a lot of multi-part assemblies to build.
Thanks all, and great to have you along for the ride Paul.
My wife was away for the weekend at a friend's 50th bash, so I've been cracking on with this.
I jumped ahead and started on the missile as I knew there was a very noticeable joint down it. Treating it similar to a fuselage I used copious amounts of glue and held it together tightly, which squeezed out a little bead of plastic that I could later sand smooth
Click image for larger version  Name:	PXL_20241006_123153685~2.jpg Views:	0 Size:	322.3 KB ID:	1235584
A quick coat of paint verified it had worked well enough.
Click image for larger version  Name:	PXL_20241006_172416962~2.jpg Views:	0 Size:	362.2 KB ID:	1235585
There's no interior to the tiny cabs but I painted them white as instructed. The funny rod assemblies are to line the various parts up and they do the job very well:
Click image for larger version  Name:	PXL_20241006_172502414~2.jpg Views:	0 Size:	478.7 KB ID:	1235586
I've also been adding lots of parts to the chassis. I'm not certain I've got all 14 wheels lined up perfectly. With 4 parts to each assembly there's a lot of margin for error, even if the tolerances are very tight.
Lots of boxes and brackets have been added too. I've pre-painted everything in 4B0 as access later will be tricky.
Click image for larger version  Name:	PXL_20241006_180508426~2.jpg Views:	0 Size:	193.4 KB ID:	1235587
And with the iconic split cab dry fitted
Click image for larger version  Name:	PXL_20241006_180611062~2.jpg Views:	0 Size:	172.7 KB ID:	1235588
A shot showing the amount of detail at 1/72. I'll have to be careful not to bury it with paint, hence me not using primer on this model, just basecoating everything in the main camo colour
Click image for larger version  Name:	PXL_20241006_180624491~2.jpg Views:	0 Size:	193.9 KB ID:	1235589
