THe Parts.
Reference material.
Hi I had just started building this when the Mil Mod news broke and if you do not mind I would like to share and finish it here.
I have tried to improve the detail at the top of the boggies, added the 2 missing bolts from the lower arm and added 2 missing grease nipples to the top end of the lower arms.
Assemeled transmission housing.
Assemeled rear engine door panel, air cleaners, replaced handel with copper wire, added weld seams around door hinges , added up & lower hinge pin bungs.
Fitted engine deck,rear air intakes,direct vision ports,F/R ventilators, 5 x armored fuel caps plus missing hinge pins and some PE grills.
Added a splash ring in front of the vision port (is to delect machine gun rounds away from the port)
Thank you for looking.
Pete :sleeping:
