Pete's Spitfire Tiger Models.
Pete this is some serious stuff you show us sir, I love every white part of it.
Glad to hear and see this one's back on Pete. really liking the work in the cockpit.
Cheers Ian, it's coming together very nicely I have to admit, first time I've detailed a cockpit so it's something a bit different from the norm for me.
Cheers Pete.
Hi Guy it's only what anyone else on here would or can do, it's nothing special but I'm pleased you like it, sometimes I think it's a shame that everyone ends up covering up all there hard work that they have out into their builds..
Cheers Pete.
Hi got th other side of the cockpit fished.
I've made and fitted IFF radio equipment, voltage regulator, undercarriage selector, IFF friend or foe unit, windscreen-icing pump, lint switch box. (will add fuel control switch)
Made and added compass, fuel primer pump knob.
Filled the slot in the centre, this should have had a bomb fitted here.
Have still got to make the gyro gunsight but need the canopy to arrive first.
Gyro Gunsight.
A Gyro Gunsigh (G.G.S.) is a modification of the non-magnifying reflector sight in which target lead (the amount of aim-off in front of a moving target) and bullet drop are calculated automatically. The first examples were developed in Britain just before the Second World War for use during aerial combat, and more advanced models were common on Allied aircraft by the end of the war.
The amount of lead required to hit a target is a function of the rate of turn of the attacking aircraft and the range to the target. The former is measured using a gyroscope in the sight, while the later is estimated by the pilot by moving a dial or pointer so that a reticle in the sight matches the wingspan of the target. Post-war models added a small radar to automate the range measurement; these are known as radar gunsights.
Gyro sights usually contained more than one reticle to assist in proper aiming: a fixed one, often just a dot, signifying the direction the guns are pointing, a moving one showing the corrected aiming point, and a ring to match to a target plane's known wingspan. A particularly advanced model, the K-14 found in the North American P-51 Mustang, had separate projectors and displays for air and ground attacks.
The instrument panel of a Spitfire IX showing the Mk IID Gyro reflector gunsight.
To set range the dial adjusts the reticle size to match target wingspan .
In 1936 Royal Aircraft Establishment scientist Leslie Bennet Craigie Cunningham suggested using a gyroscope's resistance to rotation to modify the aiming point in a gun sight to compensate for deflection caused by a turning aircraft.This arrangement meant the information presented to the pilot was of his own aircraft, that is the deflection/lead calculated was based on his own bank-level, rate of turn, airspeed etc. The assumption was that the flight path was following the flight path of the target aircraft, as in a dogfight, therefore the input data was close enough .
Mk I
After tests with two experimental gyro gunsights which had begun in 1939, the first production gyro gunsight was the British Mark I Gyro Sight, developed at Farnborough in 1941. To save time in development the sight was based on the already existing type G prismatic sight, basically a telescopic gun sight folded into a shorter length by a series of prisms. Prototypes were tested in a Supermarine Spitfire and the turret of a Boulton Paul Defiant in the early part of that year. With the successful conclusion of these tests the sight was put into production by Ferranti, the first limited-production versions being available by the spring of 1941, with the sights being first used operationally against Luftwaffe raids on Britain in July the same year. The Mark I sight had a number of drawbacks, however, including a limited field of view, erratic behaviour of the reticle, and requiring the pilot/gunner to put their eye up against an eyepiece during violent manoeuvres.
The Ferranti Gyro Sight Mk I. The pilot/gunner had to look into the
narrow field folded prismatic telescopic sight at the top of the device,
a drawback corrected in the later Mark II.
Mk II
Production of the Mark I was postponed and work started on an improved sight. Changes involved incorporating the gyro adjusted reticle into a more standard reflector sight system, a non magnifying optical sight that had been around since 1918. Reflector sights consisting of a 45 degree angle glass beam splitter that sat in front of the pilot and projected an illuminated image of an aiming reticle that appeared to sit out in front of the pilot's field of view at infinity and was perfectly aligned with the plane's guns ("boresighted" with the guns). The sight sat some distance away from the pilot making it safer to use and didn't impair the pilots field of view. The optical nature of the reflector sight meant it was possible to feed other information into field of view. In the reflector sight version, range was measured by comparing the wingspan of the target seen through the sight to a pre-set number. The pre-set number was selected via a large dial on the front of the sight, and the range was then measured by turning another dial on the aircraft's throttle.This new sight became the Mark II Gyro Sight, which was first tested in late 1943 with production examples becoming available later in the same year. Ferranti built a new factory in the Crewe Toll area of Edinburgh, Scotland to build the sights. This factory would later go on to be the center for Ferranti's long history in radar development.
The Mark II was also subsequently produced in the US by Sperry as the K-14 (USAAF) and Mk18 (Navy). The K-14 included two projector systems for the reflector sight, one with gyro correction for attacking aircraft, and a second for attacking ground targets. It was otherwise similar to the British models, although the dial for adjusting the target size was moved to the left side of the sight instead of the front. The area were the Mark II had the dial was replaced by a moving scale that indicated the current range to the target, along with a large pad that stopped the pilot from smacking their head on it in the case of a rapid stop.
The radar-aimed AGLT Village Inn tail turret incorporated a Mark II Gyro Sight and this turret was fitted to some Lancaster bombers towards the end of World War II.
The Ferranti Gyro Sight Mk IIc
German Developments
Although since 1935 the relevant German companies offered the Reich Air Ministry (RLM) a new type of gyro-stabilized sight, the well-proven REVI (Reflexvisier, or reflector sight) remained in service for combat aircraft. The gyro-stabilized sights received an additional designation of EZ (Einheitszielvorrichtung, or Target Predictor Units), such as EZ/REVI-6a.
The development of the EZ 40 gyro sight began in 1935 at the Carl Zeiss and Askania companies, but was of low priority. Not until the beginning of 1942, when a US P-47 Thunderbolt fighter equipped with a gyro-stabilised sight was captured, did the RLM speed up research. In the summer of 1941, the EZ 40, for which both the Carl Zeiss and Askania companies were submitting their developments, was rejected. Tested in a Bf 109 F, Askania's EZ 40 produced 50 to 100% higher hit probability compared to the then standard sight, the REVI C12c. In the summer of 1943 an example of the EZ 41 developed by the Zeiss company was tested, but was refused because of too many faults.
In the summer 1942, the Askania company began work on the EZ 42, a gunsight which could be adjusted for the target's wingspan (in order to estimate distance to the target). Three examples of the first series of 33 pieces were delivered in July 1944. These were followed by further 770 units, the last being delivered by the beginning of March 1945. Each unit took 130 labour hours to produce. The EZ 42 was made up by two major parts, and lead computation was provided by two gyroscopes. The system, weighing 13.6 kg (30 lb) complete, of which the reflector sight was 3.2 kg, was ordered into mass production at the Steinheil company in Munich. Approximately 200 of the sights were installed into Fw 190 and Me 262 fighters for field testing. The pilots reported that attacks from 20 degrees deflection were possible, and that although the maximum range of the EZ 42 was stated as approximately 1,000 meters, several enemy aircraft were shot down from a combat distance of 1,500 meters.
The EZ 42 was compared with the Allied G.G.S. captured from in a P-47 Thunderbolt in September 1944 in Germany. Both sights were tested in the same Fw 190, and by the same pilot. The conclusion was critical of the moving graticule of the G.G.S., which could be obscured by the target. Compared to the EZ 42, the Allied sight's prediction angle was found on average to be 20% less accurate, and vary by 1% per degree. Tracking accuracy with the G.G.S. measured as the mean error of the best 50% of pictures was 20% worse than with the EZ 42.
Thank you for looking in , hope you like what I've done so far.
Pete.
Hi sorry for my absence not to good at the moment :sick::sick::sick:.
Got a little bit done, painted the interior of the cockpit.
Sorry to all the real Spitfire fans and builders for what you are about to see but after all it's only a Toon plane.
Thank you for looking in .
Pete.
Hi Pete
Hope you feel better soon. Cockpit is stunning. Good to hear a canopy is in the post. In my experience most of the kit makers are pretty good dealing with missing/damaged parts but are often very slow.
Hi Pete
Hi Jim and thank you, the canopy is currently taking it's time to get here it's only coming from Belgium and today is day seven on its long journey, so for now the build is on hold again.
Pete.
Brilliant , fantastic detail Pete.
Hope your feeling better.
John .
Hi sorry I'm not post much at the minute but I'm back in hospital, have be since Saturday afternoon out of AMU and in a ward now, have no idea how long I'll be here this time, this what I managed before I came in.
Made up gunsight .
Painted instrument panel I've still need to add the glass reflector to the top of the sight.
It fits :surprised:.
Thank you for looking in I don't when or if this will be the last post or not so thank again.
Pete :sick::sleeping::sleeping::sleeping:.
Cracking work Pete, I truly hope you do get well soon and finish the great builds your doing.
Hi Pete
Sorry to hear you are not well. I wish you a speedy recovery.
The extra detailing of the cockpit is superb. Painting the panel needed the steadiest of hands.
Hi I never got around to up loading this lot before I went into hospital.
Made up the glass reflector
As you can see I have got out the artex roller and tried to do a camourflage pattern, applied decals,
painted canopy and propeller.
Thank you for looking in, hope you like it.
Pete.
Me again this is what happens when you have brush cleaner still in your brush when you gloss coat
Let it dry for a couple of days on the radiator and sandded it all back to base coat, rescribed panel lines and.
repainted.
A hard lesson learned.
Pete.
Hi all most ther with this one.
Came out not to bad in the end and I know I'ts missing the two roundels I messed them up :rolling:.
Thank you for looking, hope you like it.
Pete.
