Hi all
This has come out of nowhere, today I picked up the airbrush to to a couple of test pieces and no matter what paint mix or brand the airbrushes are spittling / spluttering when I open the paint feed, it gets worse as I increase the paint feed. For a few seconds its OK then gradually deteriorates. Getting this on Vallejo, Ammo and Primer. Have used all these before with no problems. Have tried both my Iwata and H&S same issue across both. If I run Cleaner through them its fine I get a nice controllable mist spray, anything else splutters. Spraying at my normal pressures for the above paints. I'm not getting any clogging either?
Kinda stuck right now, only thing I can determine is that the compressor is a little hot so I am letting it cool and check the tank drain and a little water came out not excessive though.
Any feed back very welcome
Warren
Warren
