Late afternoon all,
Thanks to the current heat wave, progress has slowed down at the table. I'm typing this and the temp outside is 36° C and probably warmer in here. Anyway, I have cut plastic, assembled some bits and even slobbered some paint about with the hairy stick...
I nipped off and cleaned up the wings to test the fit and see if a lot of work (filling) would be necessary. Only 2 clamps on each and no glue,
A lousy pic, but the fit is rather good. That was a nice surprise and the little gap on the bottom one closes when you press it together. The destructions don't explain everything and there are options for parked in the hanger or mission ready. The MG port on each side were closed in the hanger and opened for the mission. To open them, you have to saw them in half. Out with the razor saw blade and carefully, we cut one in half,
The little circle is the mounting point for the MG mount, with the other end glued inside the fusillier. Letting the nerves calm down from not sawing crooked, I cleaned up some MGs and rear turret parts, along with interior stuff. I then glued some parts in the interior. Let the glue dry and then slapped some IJN M3 Mitsubitchi green int. paint from AK on them,
The paint brushes on very good, but the color is a flashback to a pot of pea soup from years ago. I also will attempt to drill the MG barrels for realism. The top MG with the mount arms has to be cut out and only the mount added. On a mission, the front and rear MG's weren't mounted in the plane. No idea why though...
That's it for now people. Ain't much, but the heat is limiting progress of things. Thanks for looking in and please try to stay cool...
Allen
Allen
