1/24 Precedent, KD Perkasa
Guys, I would like to build this model, can you advise what comes in the box, as its advertised on ebay at the moment.
Thanks Gary
hi dabber
as far as i`m led to beleive there are two versions, a grp and a wood hull,
personally i would go for teh grp hull.
however, please bear in mind that these kits have been on the go for quite a while ( a good number of years) so please don`t expect too much from the fittings ( the detailing parts) as they`ll be made of wood.
what you should get in the kit is ( depending on which version) is wood and instructions for building, fittings and rudder and propshaft.
the 1/24 scale can be run ion either electric or ic engines.
you`ll need .....
motor or ic engine
coupling
minimum 2 channel radio set
electronic speed control if your going down the electirc route
battery if above true
if i.c route, then fuel tank and ancillaries will be req`d as extras
a big model which will take a fair bit of power to get her on the plane.
however with a bit of care and extra work they can be builtinto a very nice model.
check out www.hslmouldings.co.uk for extra 1/24 fittings
any more queries just post below, someone should be able to help
Adz..
Hello all, welcome Dabber to the most helpful and informative forum I've found yet. It i sgood to see another Aberdonian into boats I thought we were declining :shhhh: thankfully this appears not to be the case :dancing1: i like the look of the perkasas' and eventually intend buying a GRP hulled one to use with electrics (more opportunities to sail it) although if I were to restrict my self to the Duthie Park model yacht pond, the use of i.c is still perfectly acceptable there. Have you looked at the Anglai Model Centres' web page as they are the people who make the kits. http://www.angliamodelcentre.com/index.php?cPath=8_66_67 who I use regularly for mail order items and they do offer an exceptionally good service. My last order placed Thursday 16.30, goods on doorstep 10.40 on friday :grinball2: Well pleased with their attitude and completion of orders.
Let us know how you get on with the kit if you get one
cheers
p.s. off to Edinburgh for a sail tomorrow, car loaded 3 boats, 1 yacht and a barge :music_too :music_too
Hi Jim thanks for the welcome. I agree very helpfull. I will let you know how the build goes, perhaps see you at the Duthie Park.
Gary
Hi neither the GRP or the wood kit come with any sort of Hardware pack because people who build them use different power plants so they don't supply any propshafts or rudders,so you have to buy everything to run it whether electric or I.C power and when i bought mine i went for the 49"wood kit one as i wanted a challenge and i have had it for over 10 yrs and still haven't finished it yet but will be starting on it after Xmas.
Hi and thanks for that, can you give me an idea what is in the box and what by way of fittings is useable. Perhaps a photograph of yours my be helpfull.
Thanks Gary
For both kits everything from the deck up is made of ply or balsa apart from a piece of copper tubing you get in the kit.
Here's afew pics of my boat but i will take some pics of the bags of wood parts you get in the kit to build parts of the boat,also on mine i am going to make the main gun at the front move left to right and up and down but to do that i had to make the section where the gun is removeable.
Just got mine of my shelf to take a pic of some of the bags of wood you get to build parts of the boat and i can't find one part for the front gun so i will have to make a new one,also took a pic of the removable section to house the servos for the gun also i still have to fit some ply sheeting to the hull as i didn't like what they put in the box for that part of the hull so i removed it and i still need some more balsa for the front end to finish it off and some filler.
Hi Dynamite, thanks very much for going to all that trouble much appreciated my friend. You have convinced me that with some aftermarket parts this is a decent entry level RC model to purchase.
Gary
hi just seen new warship that would make a cool model it is a MRTP33. any one seen this boat or any plans let me know thanks
new guy looking for 1/32 perkasa fittings
Hi, I just ran across this forum and saw a piece on 1/24 precedent Perkasa, so I thought I would sign up and try to get some help and maybe offer some help if I can
Hi, I've come accross this forum via a link and decided to join. I am building a 1/24 precedent Perkasa, the hull and decs are excellent but the rest leaves a lot to be desired so I am replacing superstructure with my own design and build. Is there anyone out there with any information or detail on the Bofors Gun?....photos to follow...
Hi John, yes the bofors on the Percassa is a bit basic but OK as a stand-off model, Sirmar Models used to make some superb cast armaments, the company was sold to a guy in St Helens they have webb page, contact on Tel / Fax: +44 1744 850975
e-mail psships@aol.com
Hope this is of use regards Aquarama:thinking:
Hi everybody, just signed up as i have just purchased the 37" G.R.P. version, so a bit disapointed with what you get for your money. The bow section seems to be a total mismatch so i shall replace it with a single ply piece rather than the 6 pieces suplied.
Anybody with the full build experiance who can tell me of any other pit falls would be gratefuly received Thanks in advance. Grizzly
Hi Grizzly and welcome!
I don't quite follow what you are referring too when you say the "bow section". Are you talking about the deck?
I have a 37" Perkasa as well, although it is very old, and still un-built.:shhhh:Mine has a one piece deck front to rear with removable sections for access.
Terry
