1/32 Tamiya F-15E Strike Eagle
chameleon 2009
F-15E Strike Eagle
Mission
The F-15E Strike Eagle is a dual-role fighter designed to perform air-to-air and air-to-ground missions. An array of avionics and electronics systems gives the F-15E the capability to fight at low altitude, day or night and in all weather.
Features
The aircraft uses two crew members, a pilot and a weapon systems officer. Previous models of the F-15 are assigned air-to-air roles; the "E" model is a dual-role fighter. It has the capability to fight its way to a target over long ranges, destroy enemy ground positions and fight its way out.
The aircraft's navigation system uses a laser gyro and a Global Positioning System to continuously monitor the aircraft's position and provide information to the central computer and other systems, including a digital moving map in both cockpits.
The APG-70 radar system allows aircrews to detect ground targets from long ranges. One feature of this system is that after a sweep of a target area, the crew freezes the air-to-ground map then goes back into air-to-air mode to clear for air threats. During the air-to-surface weapon delivery, the pilot is capable of detecting, targeting and engaging air-to-air targets while the WSO designates the ground target.
The low-altitude navigation and targeting infrared for night, or LANTIRN, system allows the aircraft to fly at low altitudes, at night and in any weather conditions, to attack ground targets with a variety of precision-guided and unguided weapons. The LANTIRN system, consisting of two pods attached to the exterior of the air craft, gives the F-15E unequaled accuracy in weapons delivery day or night and in poor weather.
The navigation pod contains terrain-following radar which allows the pilot to safely fly at a very low altitude following cues displayed on a heads-up display. This system also can be coupled to the aircraft's autopilot to provide "hands off" terrain-following capability.
Between April to October of 2018, several F-15Es from the 494th Expeditionary Fighter Squadron (the "Panthers") deployed to an undisclosed location in the Middle East to support Coalition Joint Task Force Operation Inherent Resolve, tasked with striking Islamic State targets in Iraq and Syria. While deployed, the Panthers completed nearly 2,000 missions, over 10,000 flying hours, employing more than 500 precision-guided munitions in support of US Central Command operations. On their return to Lakenheath at the end of the deployment, the aircraft were seen sporting some very striking nose art and mission markings.
This is the Tamyia F-1FE 1/32 kit which is a dream to build, painted with Tamyia acrylics, and features 2 x Reedoak figures, this aircraft is based at RAF Lakenheath
Mike,
Another cracking build to add to your collection. What are the white rectangular items under the cockpit and on the rear?
Mike,
Hi Paul thanks for the comments, I think your referring to the slime lights, these are light up at night so they can be seen on the tarmac
Mike
