1/35 Hornet heads
Hi Guys , Does anyone have any experience with hornet heads , at the moment I`m concentrating only on 1/35 figures for my dios , I would love to use resin figures but they are so expensive , are hornet heads worth getting if so do these heads fit tamiya and dragon torso`s with a bit of trimming here and there, also being a novice is it just wise to try and master the basic heads first then move on to the hornet heads when more experienced,
Any advice is very welcome
Richy
Hi Richy, I haven't used them myself but from what I've read, Hornet heads are very well respected for their quality & detail. I think to use them to best effect, your painting skills would need to be tip-top. I certainly wouldn't try them yet! I think they would fit most figures with a bit of trimming & filling, especially if used with Dragon Gen2 figures as these come with separate heads already. In fact, I would recommend this line of figures (if the ones available fit your dio plans) coz they're very detailed-a good middle ground perhaps. Patrick
Cheers Patrick , If I think about it - your right - while I`m still learning maybe its better just to stick to the basic kits and try to get the best out of them as I can without throwing my hard earned down the drain, its hard enough trying to get a figure looking okay without everything else involved , its a massive learning curve but I`m loving every minute of it , trouble is I`m trying to run before I can walk ,
With so many modelling extras out there its hard not to get involved,
I`m turning into a modelaholic
Richy
Funny you should mention separate heads, the figures that come with the Tamiya Field kitchen have separate heads. which I hope, given the raised collar on the body neck will help get a more realistic line between the head and the jacket. I wasn't aware that you could buy third party heads.
I know the feeling mate! My credit card burns a hole in my pocket every time I go online! And just to answer Graham, I don't know about that Tamiya kit, but the Dragon Gen 2 figures I mentioned not only have separate heads but also separate boots & hands so you get a very realistic look. Even the weapon muzzles are drilled out! Patrick
