1:35 scale wooden bridge
would anyone have any plans for a basic wooden bridge or even a bailey type bridge. i have an idea for a dio but cannot seem to find any basic plans or sizes for such a bridge. i have seen some manufactured by a company called bastion 35 but would rather try building some myself.
Andy one of the guys here has bought the bronco bailey bridge if you find out who it is they could give you the measurements based on the kit, i don't have that dio anymore gave it to a charity raffle at work...... sorry mate.
scott
Hi Andy i have a Bronco bailey bridge, give me a little time and i will send you the measurements you require, i also have a Bastions bridge that i have just built i will send you the measurements of that also mate.
Tom
Hi Andy i have some measurements for you, i have taken these from my Bastions bridge kit, it is the multispan beam bridge L class(well thats what is says)
The overall height of the bridge is 100.6mm/ 4.5 inch(this is from the base of the stanchion support to the top hand rail
The stanchion supports (8 in total) are 65mm/ 2.5 inch in length, the stanchion supports(round dowel) are 6mm in diameter.
The bridge has 4 long beams running the length of the bridge these are 185mm/ 7.5 inch, these are placed on top of 2 wooden seperate beams 100mm/ 4 inch , 5mm square these are placed on top of the stanchion bases.
There are 31 wooden decking planks these are 90 mm/3.6inch in length, 1mm depth , 5mm wide.
There are 4 cross member planks these sit across the stanchion supports these are 100 mm/ 4 inch, 1 mm depth, 7 mm wide.
This type of bridge has guard/ hand rails these are the same lengh as the 4 wooden beams 185mm in length, there are 6 of these they are 3 mm square, there are also 8 down right supports for the guard/hand rails these are 3mm square and 25mm/ 1 inch in length.
I have added a few pics and i hope this helps with my measurements so that it gives you a rough guide in the measurements and how this type of bridge is put together, if there is anything else you need help with please let me know.
View attachment 44173View attachment 44174View attachment 44175View attachment 44176View attachment 44177View attachment 44178View attachment 44179View attachment 44180View attachment 44181
Andy if you go onto the Bastions site they have different styles of bridges, these are all different styles and some of them look really good, especially the super heavy bridge for heavier loads, you may well want to do something like these, i have posted some pics of these from their site, see what you think.
View attachment 44182View attachment 44183View attachment 44184View attachment 44185View attachment 44186
Tom
Hi Andy
I hope you could make sense of that lot, and i hope the pics were of some help, i have added a link for you in regards to the Bronco bailey bridge this comes with very useful info along with pics and measurements and a review of the kit and its parts, i hope this is of help to you.
Let me know how you get on and if you need any further info or help.
http://www.perthmilitarymodelling.cBronco Models Bailey Bridge Type M2om/reviews/vehicles/bronco/cb35012.htm
Tom
thanks tommy, thats exactly what i need. this is just an idea i have forming in my head for a dio and i have stacks of balsa and dowels lying around.
