1/48 Tamiya P-47D
\ said:
Good video here from Humbrol if it is of any use to you:
Thank you for sharing the video with me, it was very helpful. I ordered all three types of clear cote and they should arrive soon. What do you use to clean the clear coat out of the airbrush?
Thanks
Treat it like any enamel paint, I use thinner or white spirit. Apparently you can use cellulose thinner as well but I haven't ever used it.
It's my favorite aircraft of WWII.
Good job ;) .
Regards
ajcmac
Hello,
It has been a long time since I last posted, this is because the Humbrol clear coats that I was going to apply onto the model got lost while they were getting delivered. I'm trying to get some new ones but I think ill get a replacement only by next week. In the meantime, I decided that I was going to make a base for the P-47 out of a piece of MDF. I also finished the 1000lb bombs.
The bombs painted Tamiya Olive Drab and masked out, ready to get the yellow line airbrushed on
I think the line turned out quite nicely, without any major paint bleeds
The bombs in place
I have noticed a gap near the bomb pylon, I will try to fix that with some putty
Applied quite a thick coat of glossy wood varnish to the piece of MDF
After a bit of sanding the varnish, the finish was very smooth and glossy. I am going to paint the top in grey and the sides in white
I think this is a good size base for this plane, I am planning to make an airfield diorama on it
See you next time
Ok, so I continued working on the base. Finished the spray painting part and hope to soon start adding more detail such as airfield items, airstrip plane guidance lines and I hope to incorporate the tamiya 1/2 ton refuelling truck into this diorama.
the grey top colour applied
and masked off...
Masking tape removed, the paint boundaries are quite neat.
See you next time...
I have finally received the humbrol clear coats, but, the flat clear coat did not arrive yet. After paining the entire model with the clear coat, I got concerned. Why did the clear coat that was meant to make the surface smoother create small bumps on it? The base seems to be coming along nicely, I painted a dotted guiding line on it, although I am not sure that I like the "oil/fuel stains" that I created by spilling diluted black paint on the grey.
To clean the airbrush, I used the thinner
The part behind the cockpit has got some rough surface that was not there previously. Does anyone know why?
Masking off so I can paint the yellow guiding line
What do you think of the oil/fuel stains and the weathering? I am planning to put small fuel barrels in those spots
No idea why you would have got those bumps behind the canopy area, Ivan. Is it possible it dried in the air prior to hitting the model? Overall it looks pretty good though.
I don't think it dried in the air because I was holding the airbrush close to the surface. I hope that this won't be much of a problem because there are no decals in that area.
Have not posted in a while but during this time, I finished the model. There are some major flaws such as missing decals because I was not being careful enough and ripped them but otherwise, everything went fine. After applying several clear coats, I started the decalling. The decals supplied were very good. Once the decals were put in place, I applied several layers of the humbrol matt coat and removed the canopy masks. Unfortunately, you can't really see the interior of the cockpit. For the base, I added an area of grass and am planning to build a refuelling truck to complete this diorama.
Too much micro sol and fiddling around with decal while not being careful is a recipe for disaster.
I tried to add a wash, but it did not work.
decals applied, clear matt coat ready to be airbrushed.
Lear coat applied, masks removed, unfortunately you can't see much detail
I used an old brush to "paint" PVA glue over the surface where I wanted grass, then I sprinkled an excess of grass powder. Once it was dry, the powder was shaken off.
Finished model on base
See you next time.
