1/72 F-22A Raptor
This Hobbyboss kit is a F-22A – single-seat production version which was designated F/A-22A in early 2000s. It's a 2009 new mould & typical of HobbyBoss so it's really well done. Moulded on 4 grey plastic & 1 clear sprue, it's a very detailed and worth-the-money kit with full-detailed weapons bay. Not only that, it has wing racks for those JDAMs.
The decal is only one option: the 422d Test and Evaluation Squadron (422 TES), known as the "Green Bats", it's a part of the 53rd Test and Evaluation Group and operate out of Las Vegas, Nellis Air Force Base.
Tail code on the decal is: OT 010 AF00. It should be the F-22A PRTV (Production Representative Test Vehicle) Raptor, 99-4010 of 422nd TES.
Box art:
Here's some grey sprues:
\ said:
Some updates:
Cockpit, instrument panel and ACES II painted with Gaia Ultimate Black + Flat base.
HUD and cockpit done washing and panel lining.
F-22A Gold tinted canopy color testing.
Clear Orange - Clear Yellow - very thin layer of stainless steel and Red Gold.
Any suggestion?
It all looks good Kitti nice colour for the tinting they look very similar but the one on the left in the second photo looks best.
This looks very nice kitti and I'll definatly be watching this to its completion.
I really like the ring and explanation added to it as this looks most authentic. Lovely details
Regards
Robert
Guys! Some updates here:
Sometime it's not good to stick with the marking/painting instruction, because they'll bring you to somewhere you doesn't like.
I follow the painting suggestion and everything goes wrong, they suggest 308 as base coat and 305 as the camo, no contrast on the camo and I need to repaint it with Darker Gray (Gunze 317) on the camo part but luckily the outcome is much better than before.
Ballast-ing, ok basically they're made of ceramic, just like your kitchen tiles, almost +300gm here.
Primed:
Masking aint easy:
Wrong painting suggestion!
And then I repaint the camo with Gunze 317, now it looks much better and contrast too:
The different:
After some panel washing and little bit refine work:
Gun Metal & Burnt Iron on the exhaust.
Locked n' loaded. GBU-12 LGB x4, AIM-9 x2 & AIM-120C AMRAAM x6 & JDAM x2.
That's all for today, continue after work.
Cheers!
That is looking very good Kitti, and i see what you mean about the colour and it looks great armed to the teeth.
This is really nice. Very brave work on the canopy, I would never have the confidence to try that but it looks brilliant.
60% done, it's time for detailing and diorama!
This HobbyBoss 1/72 F-22A Raptor really killed me badly deep inside me. First, the painting scheme suggestion is totally OUT!! Very low contrast between two type of grey and can't see any camouflage. I save the day by spraying Gunze 317 onto the camo pattern.
Yea for canopy, I done it by spraying layer by layer. Clear Orange, Clear Yellow and then very thin layer of Mirror Light Steel.
In fact, a lot of mistakes and messed up a lot, let's take it as a lesson and gains experience with it.
Good day! Some updates:
Airfield, very simple one.
Masking to spray yellow for those lines.
Done, it's very easy and simple.
Title of the build, applied directly onto the airfield by using waterslide decal. The gold fish, it's also waterslide decal printed with Gold.
The 'Remove before flight' tags added.
Pilot painted. Done tags, done airfield, done pilot, done everything.
That looks great Kitti I realy like the base it sets it off nicely, but what i realy like is the colour to the cockpit glass top job.
