1/87 Motorized (RSO) 21 & 15cm Nebelwerfers
minitnkr
Charter member of Rabble, bed# 105
Paul
Dayton, OH USA
ROCO RSOs detailed & conversions in hasty deployment of modified 21 & 15 cm Nebelwerfers. Initial config.Initial config.JPG
Funk coffer
RSO w/drop in Drilling
Working RSOs...cleanup, drilling out boggies, adding hitch, steering handles, pioneer tools, paint, windshield glazing & triming side curtains.
C&Cs welcomed. PaulE
Brilliant Paul. The coffer is sublime. Looking to build that caterpillar type thing myself soon. May do it in 1 35 as it looks small to begin with :smiling:
Thanks guys. Rick, the 15cm pair are (plastic) Preiser I think. They came with fixed trails & third leg in the firing position, so these are modified to pose in either position. The four 21cm are (resin) Heiser I believe. Two in tow & two in firing positions. The two in fixed firing positions have been modified to support either. PaulE
PAK element of security section.
15cm NWs almost ready for loading. Still looking for appropriate figs.
Two 21cm NWs being deployed while two more approach. Still working RSOs.
C&Cs encouraged. PaulE
As always Paul you can see the amount of planning you put into a dio, top marks buddy.
The camo looks nicely painted .
Dzhon .
Preiser used to make a pak crew are they still available or gone the way of the Dodo bird?
Don't know what you could use for the Nebels. At any rate you have a good showing there.
Rick H.
Thanks guys. RickH, they are are still available I think. I have several sets. I have some Preiser 10.5cm crews that may serve the Nebels.
NW A arriving.
NW C&D deployed as B arrives.
Ready rounds distributed.
RSO/2 mit funk coffer
RSO/2 mit Drilling
Working remaining RSOs
The ground level shots are awesome. The RSO/2 mit Drilling photo is just insane. Wonderful work Paul. You must be pleased how its turning out.
Thank you Ross, Steve & Scottie. PaulE
Wow!! Are the flat-nosed RSOs early of late models? I only remember the ones with what looks like a truck front end
PJR RSO/1s are the early rounded ones,. The squared ones are the later RSO/2s. They made a few RSO/3s (/2s w/Diesel engines). I think this is done unless you guys have some suggestions. C&Cs encouraged. PaulE
Really like the RSO with the tarp sides rolled up. Gives you an opportunity to show what's inside.
Nice! Rick H.:thumb2:
