1/87 PzrIV Beobach w/PE schurzen
How you manage at this scale is a tribute to your skill. A star antenna and PE schurzen is simply really icing the cake.
Changed my mind & put MkIII Beobachs w/Hummel battery elements so these two will go to the Wespe battery elements when completed. While I've been working the Beobachs I've also been working a MKIV medium tank platoon.
Gosh i doth my cap to you.Thats exceedingly great work in this scale Paul.Excellent.
....working...decided these would go to Wespe battery elements.Click image for larger version  Name:	100_4486.jpg Views:	0 Size:	314.7 KB ID:	1263387
Unbelievable attention to detail and soooo big - I would need to remove furniture in my space to accommodate a scene so large.
Thank you gentlemen. Quality Wespe are hard to find in this scale so 233 & 236 are in for repairs & 234 is lost to counter battery fire. One of these in the photo is made of a WSW ammo carrier & Preiser 10.5cm howitzer.
Finally scored another ROCO/ArsenalM Hummel. Will build up & show w/other Hummel elements including two PzrIII Beobachs. Initial work was disassembly & acquisition of additional pcs. & decals to finish it off. Things to the right of the left side tracks are additional to the model as delivered.100_4537.jpg
