ok, as some of you know i am soon going to be starting the Tamiya 1:350 Musashi,
something toby and i were wondering on is how comes for 3 of the paints you are ment to use enamels, and the rest are acrylics?
the 3 colours they ask you to use enamels for are:
XF-11 - JN Green
XF-12 - JN Grey
XF-9 - Hull Red
(im guessing 'JN' stands for "Japanese Navy", please correct me if im wrong)
Is it something todo with the heat/water resistance of enamels or something? (baring in mind this kit is made so that it can be built as an r/c)
also, seeing as i have not used enamels in oever 5 years, how do i spray them? i have enamel thinner which i baught today, what is a good ratio to stick to when thinning the, down? is it the same "milky" consistancy of acrylics?
what did you do on your bismark Richard?
XF-11 - JN Green
XF-12 - JN Grey
XF-9 - Hull Red
