Acrylic varnish
I've tried a couple of different flat acrylic varnishes and was just wondering which products you use and why you prefer them.
I would of started a poll but couldn't work out how to do it.
Cheers guys
My preference was for the Tamiya Matt varnish in a spray can, because I never had any problems with it, no white patches at all.  But I cannot find a supplier locally.
I tried the Humbrol Clear Matt through the airbrush as the Gloss version works well, but I have never managed to use it successfully.
I am now using the Winsor & Newton Professional Matt Varnish in a spray can and I am really happy with it.
For small patches with a brush I use the Vallejo Matt varnish.
Humbrol Matt Coat all day long! I've never had a problem with it in 8 years. The key to success with any matting product is a lot of mixing. Mix, mix & mix it some more!
Gunze flat matte varnish sprayed with an airbrush.
Thinned with Mr color thinner
Have never gone wrong with it
After a nasty experience with the Vallejo developing white flecks, I now use Winsor and Newton Galeria Matt. Thin in down 2 parts varnish to 1 of water and it produces a beautiful matt finish with a really thin coat.
At this rate you'll have a recommendation for every product on the market and you'll be right back where you started!
I had a horrible time spraying the Vallejo flat and haven't had the courage to try it again.
I just used Model Master Acryl Flat and it sprayed like a champ right out of the bottle... no thinning necessary, and a nice flat coat.
I also had trouble with Vallejo matt - white spots all over, despite vigorous shaking. I have turned to Tamiya mat in a spray can. It works. The solvent/cleaner is Cellulose Thinners.
I agree with John about Alclad Aqua Gloss - it's the best gloss coat I have ever used.
For a matt coat I use Winsor and Newton Galeria Matt. - which I also really like.
I have had white speck problems with both Humbrol and Vallejo matt in the past - and I don't like using a spray can because I find I end up with too thick a layer on.
I am another who uses Alclad Aqua Gloss (though I have a bottle of the new AKI Gauzy gloss coat to try as well).  For matt I too had some problems with white flecs on Vallejo Matt however I have not had problems after stopping tearing off strips of kitchen roll after matting a surface!!  You get very miniscule airborne particles when doing that.
More recently though I have changed to the AKI Ultra Matt and find it superb.
I use Vallejo matt mixed about 1:2 with Klear for finishing most of my aircraft. It gives just about the right amount of satin/gloss to the finish, which I do not want to be dead flat.
I've never had any problem with white flecks, maybe I'm just lucky :)
Cheers guys
I just use Halfords Alan :)
Well, I can happily report that Mig Matt Acrylic varnish (A.MIG-089) works superbly, straight out of the bottle. It has a ball bearing in to ensure good mixing, and it slips though the airbrush without any dramas whatsoever. Even better, the final result is a clear, fully matt finish. Shouldn't be hard, should it? ;)
one question as a beginner. how is better to apply warnish on the model, brush or airbrush?
