I am trying to stick plasticard to plastic piping as used in domestic plumbing, e.g. sink waste pipes, so far without success.
After roughening the pipe surface, I have tried superglue, solvent adhesive as used for brown plastic main drainage, 5 min. epoxy, Plastic Weld, AmBroid Proweld and polystyrene cement. At best I get a weak bond that does not stand up to any handling; at worst I get no bond at all. Has anybody had the same problem and solved it? BM
