Advice needed please
Hi guys , just got back into modelling after a long absence. My first build has been a Lancaster B.III Dambuster , anyway all has been fine painted the model using humbrol enamels and failing to source a clear coat I ended up using a laquer I had in the shed. It has totally ruined the finish, is there anyway I can rescue the model? will it dry properly? can I used it as a feaure to show battle scars HELP!!!!!!!!!!!
Hi David, welcome to the forum.
Sorry to hear of the issue. Has it gone crazed, if so there is little you can do expect try and strip the model back, not something I would do. You could wait until dry and then get some really fine sandpaper and gently go over the model, it may take the laquer coat back and dull the surface, making it look worn.
Thanks , yeh it has a crinkled effect going on buy only on certain areas the paint chip effect had just been completed ready for clear and weathering , it does have the look of a battle scarred plane something the plane surley would of had anyway I might still be able to weather effectively and use it as a feature, I really don't want to strip back the paint lol
If the lacquer has only affected certain parts of the model, why not turn it into a feature? Add some holes in those areas to simulate shell/cannon damage.
Other than that, as Si has said you're only option is to sand down the affected areas & repaint.
In the meantime, have a look in John's store on here & get some acrylic clear coat. That'll prevent further disasters ;)
