After seen this you will never see the AVRO CF-105 ARROW the same way !
JMARC
HI GUY'S !
Just like the title said ..I been working for a while on this project I have completed 89 AVRO CANADA projects so far and still a couple to do before I move on to another project ..So here below what on my work bench at the moment.. Remember all projects are done in 1/48 scale ..I work on this project on a weekly base so be ready for some update .. Note due of picture limitation I have created a page on google for each projects where you will be able to view where I'm at on each of them .So here they are
# 1 AVRO DTV (Delta Test Véhicule )
(MAY 06th) so far I have created the phase 1 and 2 DTV and rocket booster , I'm working on the launcher now
If you like to view the complete WIP on this project , I have set-up an Google page for it ,on GOOGLE ,here the link:
https://photos.app.goo.gl/mteEH2v7U1HjPssE6
#2 1/10 AVRO ARROW FLUTTER test model
(MAY 06th) So far the basic work on the model is done and I'm working on the decals and last details
https://photos.app.goo.gl/DvrVTZbBUFoAfKBSA
# 3 .....AVRO CF-105 ARROW MACH 2 WOODEN MUCK-UP
(MAY 06th )So far it's almost done, what left are last details and scratch the nose radar , last work was retouching the nose paint and complete the main gear door and glued it into place
https://goo.gl/photos/jXeQLJioaoky58HR9
# 4...ASSEMBLY JIG
(MAY 06th).. the main JIG is completed, what I'm working on now is adding details and created the assembly buggies that hold the main parts , last work I done was creating a metal shelving unit and advance the middle fuselage section buggy
https://goo.gl/photos/d6TczBBAmLeLeeGRA
# 5 MASTER MOLDS
(MAY 06th).. So far I have created pieces and prepare the presentation , at the moment I done the last work on the FUSELAGE TOP PLATING MOLD and created a working table that will be display shortly on the presentation base
https://photos.app.goo.gl/3pBpv8FH0OhzQalQ2
# 6 OPEN / CLOSE CANOPY TEST JIG JIG
(MAY 06th ) I'm almost true with the jig itself, the last work I done was creating the opening/closing mechanism
https://photos.app.goo.gl/5ZN3L1Yi9pQUJMz28
# 6 OURANDA IROQUOIS ENGINE
(MAY 06th) So far the engine basic work is done, I'm now at detailing the mid section !
https://photos.app.goo.gl/z9mSKHrEf6z84nGQ9
# 7 AVRO CF-105 INFORMATION CENTER
(MAY 06th) So far I have created several small section and I have yet to determine the size of the presentation I will need , the last wrok I done was the INTAKES and EXHAUST covers
https://photos.app.goo.gl/3n8AXR62ufi2hADi6
# 8 ARRESTING HOOK proposition for ARROW MACH 2
(MAY 06th) So far I'm almost true with the engine section that will hold the head of the hook and action mechanism
https://photos.app.goo.gl/eD3gocMQTDWTD7cT6
# 9 FALCON MISSILE JIG proposition
(MAY 06th) I have done the basic work on the jig last work was creating the legs to hold it
https://photos.app.goo.gl/QLehPpReQr6VuMWN7
#10 CF-15 ARROW TOW TRUCK
(MAY 06) the main body is done on both version , the last work was on the front grill of the first version
https://photos.app.goo.gl/e3nTY3GAFPhoyKxh7
# 11 Jeep M.38 GÉNÉRATOR
(MAY 06th) .Using the REVELL jeep , I made the necessary modification, I,m at completing the back doors
# 12 WHITE 3000 gaz truck
(MAY 06th) So far using the REVELL kit , I have modified the frame and Im on creating the back section
#13 disassemble of the ARROW # RL-205
(MAY 06th) The RL-205 is completed , the presentation base is prepared and I'm now creating all the wings disassemble parts
Si vous désirez voir le montage intégrale visitez ce lien Google
https://photos.app.goo.gl/1TVjeJLmC4Zxcekd6
(MAI 06) Cette semaine j'ai pris une pause sur ce projet !
Enjoy ..
Jmarc
MAY 09th UPDATE !
(MAY 09th ) Today I started the belly electronic access door !
# 4...ASSEMBLY JIG
(MAY 09th).. Today, I started to add detail to the metal shelving unit !
# 5 MASTER MOLDS
(MAY 09th).. Today I started a couple of maintenance pails !
