Hi there.
I'm having trouble getting paint out of my airbrush and I don't know why.
I've been using Tamiya acrylics and Tamiya thinner (1 part thinner/2 parts paint) on a siphon feed brush and it's been working fine.
I now have a different paint - Gunze Sangyo Aqueous Hobby Color - which I've thinned (same ratio as before) with Tamiya thinner. The only problem is it doesn't seem to be coming out as well as the Tamiya paints did. I know the brush isn't blocked because I always make sure I clean it well after use. I've also tried adjusting the air pressure but this doesn't help much.
Any ideas?
Should I thin/thicken the paint a little more?
I've put a first coat on and it's pretty patchy and took about twice as long as it has in the past.
I'm pretty new to airbrushes so I don't know if my ratio is right to begin with but up until now it's worked okay.
Any suggestions would be welcome.
Cheer
Any ideas?
Cheer
