HI, Thought I would make a start on this. HMS Marlborough was one of the Iron Duke class of ship and the first ship my father was posted to back in January of 1929. I thought I would have a bash at changing Iron Duke to Marlborough. Fortunately all the photo's I have found so far show very little change just a second mast towards the stern of the ship. I did think of the Combrig model of Marlborough but never having done a resin kit I though I would start with what I know, also it costs a lot more. As we know its an old kit but with the exception of a bit of flash it doesn't look to bad in the box. So far I have put the hull together, this didn't seem to want to line up and the indents at the stern for the rudders and stern gear were out of line. After some fiddling it appeared that the two midships locating pegs were causing the problem, once thay were got rid of it all lined up ok. I had great difficulty with the small guns on the side of the deck as the pins on the housing they were in were too big for the locating holes. Once that was sorted out I found that the holes in the small guns were then too small for the guns to fit over the pegs. After enlarging the holes during which I was lucky to only break 4 of the gun barrels off I got them all on then it was just a case of drilling small holes and locating new barrels from stretched sprue. I hope that will be the worst of it but probably not...
