Airfix Severn Class Lifeboat
Gents.
Please can anyone help with tips and or Advice on building the subject lifeboat, I normally build aircraft so wouls appreciate any help.
Thanks in advance
Jim:regards:
Hello Jim, Wash all plastic components in warm soapy water and allow to air dry (to remove any release agent) there is a plastics cement with a 'hypodermic type nozzle' this gives an A1 delivery of adhesive, follow build instructions in the makers order, pre paint as much as you can but mask off bonding surfaces, if you are using 'Dayglow' orange for the superstructure it is very sticky and will not brush out, its a case of good quality flat brush and get it right first time or it will dry streaky. The only other way is air brush several coats, get the motors and radio gear in place before fitting decks, it is worth doing a mock up of the inside of the hull and placing every thing out to check positions, access etc. regards, Aquarama:thinking:
its also just about possible to make it a Micro Rc model too !
Thanks guys, will bear all the advice in mind as I work my way through the kit. If it is any good will post some pictures when finished.
Thanks again
Jim, as this is one of the latest offerrings from Airfix I would be very interesting to see just how good the standard of the kit is and, more to the point, how do they now measure up to the Japanese/Chinese offerrings.
Any comments and pictures during your progress will be very much appreciated.
Im about halfway building one of these airfix kits, going well, but yes its far better to get all the internal painting done in stages first and make sure you get paint, where it can be seen through the hatches and windows before you affix the superstructure completely, so dry fit the upper structure first and confirm alls painted! not as I did, think you've done all the painting, then apply glue to the upper section, go to fit it and then find........
just shows how quick you can seperate two items that have been glued together !
