Hi all. I know I'd planned something more impressive and more in keeping with a tribute to Simon, but after several very stressful trial assemblies, I've chickened out! :smiling5: It'll still happen, but only once my head's in a better place, and probably behind closed doors.
So instead I'm doing a straightforward OOB build of this Meng Typhoon. Nothing fancy, but it's the thought that counts, and it has to be fun!
According to the blurb this vehicle was designed for the Russian Special Forces (VDV). The kit itself seems very cleanly moulded, which is a good thing as the light grey plastic makes it hard to spot any mould lines etc. It has movable steering and even sprung suspension, a well detailed interior, and an optional 3 colour camo scheme that I'll probably be trying to replicate.
Obligatory sprue shots first:
And the paint schemes
First up was the lower hull, shaped to deflect mine blasts. There were quite a few step to get to this point, but I got carried away and forgot the pictures
And a top view, after adding the front bumper. The brake assemblies are loose fit for now as it'll be easier to paint them off.
Then we come to these parts, which push and turn into a key slot, so the springs actually work. A bit of a gimmick maybe, but at least I should get all 4 wheels on the ground.
And fitted to the floor section
The floor and hull were then married together, after much fiddling to get the spring assemblies clicked into place on the suspension. The springs were forcing the two sections apart slightly, so they'll be clamped up overnight.
