hi guys I am building a base for my Sherman in the sig group and using polystyrene as the base with balsa sides , I wanted to texture it with say plaster , what is the best way to get it to stick or apply it ? any advise is very welcome .
If the polystyrene is smooth (like what is used to make models) PVA glue would, I think, be essential to get plaster to stick. If it is expanded polystyrene (like in packaging) I think the plaster might stick well because of the rougher surface, but I would still use PVA. Also, a coat of PVA brushed on the top of the dried plaster might help to strengthen it and prevent cracking.\ said:hi guys I am building a base for my Sherman in the sig group and using polystyrene as the base with balsa sides , I wanted to texture it with say plaster , what is the best way to get it to stick or apply it ? any advise is very welcome .
Mixing with PVA should give you a better mix than just painting PVA on and adding a powder or plaster. Coat with PVA when dry to seal, once dry AB or paint to the desired colour.\ said:im using polystyrene from packing which I have shaped with a hot wire , it is encased with balsa sheets, thanks for the advise guys I will give it a go with mixing pva to the plaster on a pva coat and see how we get on![]()
