It seems that a tutorial on this subject would be an overkill,but not so as modern waterslide transfers are so thin and fiddly that if you dont stick to a system you can get into a bit of a mess with them.What better than seeing how the experts do the job at the professional model building workshops,faced with a task of producing hundreds of airliner models for travel agents windows they have to get things right first time round.The problem is whilst modern decals have got better and more realistic with thinner carrier film they have their drawbacks,they tend to curl under as static takes effect,the solution is plenty of water applied with a brush onto the models surface,literally flood the area so that suspension of the water carries the decal before it is smoothed down,also dont be attempted to take the decal out of the water too soon otherwise proper wetting out will have not taken place,take the piece from the water and hold the backing paper against the model,wet your finger and start to gently pull the backing paper away at the same time hold the decal in place at the edge with a cotton wool bud,if the transfer is quite long then pull swiftly to keep the decal straight such as on a airliner stripe etc,too slow and undercurl will take place and difficult to get straight again,if this does happen dont panic but flood more water onto the transfer and with a small brush gently tease out the decal flat again,once this has been done take an absorbent tissue and hold it against the transfer,this will remove the excess moisture,once this has taken place put the model aside for a few hours,it is so easy to move a decal and ruin it should you stick your thumb inadvertantly onto it ! work slowly and carefully.
Once the transfers are dry always protect them under a coat of suitable clear finish,acrylic varnishes do not dry yellow as some of the older enamel based ones did,but my good old standby is Johnsons Klear,you just cannot beat it for this type of work,it sets beautifully clear,is thin to apply and seals everything,a bottle will last you years and you will find all kinds of jobs for it.
