hi all,
well i finally took the big step to take this modelling lark a bit more seriously so I've invested in an airbrush (Aztek 4809 set) and as above a Badger BA1000 piston compressor (has a guage, water trap, air filter and regulator), I dont have a tank of any sort. I've watched the dvd about the airbrush and that seems to be ok, just a case of getting used to it. its the compressor that i have a couple of questions about so here goes, hopefully you guys can put me straight.
I connected it all together turned it on and the guage went upto 60psi then turned itself off untill it dropped back down to about 40psi. when i press the trigger fully on the brush the pressure drops to around 20/25psi, then lifting my finger of a touch the pressure goes up and down. so figure this is how its all controlled, but it never goes above the 20/25psi, is this correct?or am i being a numpty and using it wrong already
the next question is the glass "jar" where the air filter is has a valve on the bottom and it seems that air builds up in there, if you try to press the vale to release pressure it is ver hard and then a sudden rush of air. there is a red plastic nut on the top of the regulator that "loosens" the top, a bit like a pressure cooker valve, is this supposed to be loosened off when spraying?
I've not got round to putting paint in yet I'm jsut trying to get my head round the workings of it all. sorry if this is asking the same as others but just went through all the 154 posts and although i got some info, I'm hoping someone else has the same set up I have now. if this works out an i get into it I dare say i will get new kit after getting used to the game/skills I hopee to pick up.
cheers - Rob
cheers - Rob
