Can anyone tell me the best way to use Balsalock on liteply please.
How long do you let it dry out before applying your covering?
is balsalock simlar to clearcoat ?
yea i knew clearcoat is for finishing i did a bit of googleing at college and it i found a little tut for patching and the person who wrote it said to apply a thin coat around the edges of the patch area
speaking of patching do you have any tips on this as on my plane(not finished yet) i burned a hole in the solarfilm due to the iron being too hot so i need to patch this but dont know how to do so
damn
i just realised sorry for hijacking the thread i really didnt mean to
*** Cut a patch with pinking shears larger than the tear' date='apply a very thin coat of balsaloc to the area that you intend to patch,set your iron on medium and tack the patch on each corner,then apply the iron all around the edge,finally tighten up with an heat gun,that should do the job.[/quote']is the balsaloc necisary? i dont have any and there is no model shop near me now
Pheonix' date=' your nearest model shop is in Dingwall 12(?) miles away, train or bus regular services. High St. near clock tower.[/quote']yea but money is a bit of a problem here fir me atm
i will maybe have a drive up there when i pass my drving test
