I am almost embarrassed to ask this question, but I think I need some remedial education in priming and painting. I recently stripped the paint off an old metal locomotive shell with acetone, and re-primed it with Floquil grey primer (enamel). After letting the primer set for 24 hours, I put a top coat of Floquil black enamel over it. The primer bled through the black, making a mucky grey in spots. (BTW, these paints were brushed, not sprayed.) Seems like the enamel reacted to the top coat.
So, is it a no-no to use enamel top coat over an enamel primer? Should I alternate acrylic and enamel coats? Use different brands?
Any help appreciated!
Rob
Rob
