Best approaches for designing and printing custom parts for scale models?
reynsi
reynsi
New york
Hi everyone,
I’m getting into 3D printing specifically to help with my scale modelling projects and would love some community insight.
I’ve seen members discuss printing missing or customised parts for kits and scratch builds, but I’m unsure about the best workflow from design to final model.
What CAD software do you recommend for designing parts that will fit accurately into existing kits? How do you handle scaling details without losing fidelity?
Any tips for successful prints (resin vs FDM) and post‑print finishing techniques that work well for scale models would be really appreciated!
Hi everyone,
Any tips for successful prints (resin vs FDM), using a 3D Printing Service, and post‑print finishing techniques that work well for scale models would be really appreciated!
thanks in advance for any help
...What CAD software do you recommend for designing parts that will fit accurately into existing kits? How do you handle scaling details without losing fidelity?
I use some old software from work, but if I have to recommend software I would say try to learn 'Autodesk Fusion (Fusion 360)' which is free for personal use and is quite popular.
I measure existing parts with calipers.
If you need to remodel something with a complex outline/cross section you can 2d scan the part or take a photo, then use the image on a 2d-plane in the software, scale it to your measurements and draw your new part on top of the image so it will fit the outline.
I designed a lot of models in the past for any scale and most of the times details are adapted to the scale; a U shaped handle on a tiger tank in 1/35 would be designed like the real thing - but in 1/144 it might be too fragile in resin to clean, or causing misprints, so that same handle could be drawn as a tiny box with rouned corners.
The same goes for tickness, a part in 1/35 with thin walls will get too thin if you just scale it down to 1/144 and send it to the printer. So you need to design the part for the scale you want it to be.
I use both FDM and resin, I don't recommend FDM for typical fine scale models but it works for very large scales. FDM is great for tools or even diorama bases that get either sanded or textured with earth/mud/stones.
Hope this helps somewhat, goodluck, cheers
