Until recently I used Vallejo Surface Primer applied by airbrush. Sometimes I later touched up small areas with a small brush, for example where the airbrush missed due to the method of supporting the part (eg., tweezers). I now use"Halfords Primer" which is in a spray can. Not "Halfords Plastic Primer" which people on this forum recommended but there's not much difference and I had bought a huge can of it.
When recently touching up as mentioned above but with Halfords Primer, it dried on the brush very quickly and when cleaning it in water it was gummed up. Obviously it uses a smelly solvent, not water. I was faced with a ruined brush but then I cleaned it with IPA, Isopropyl Alcohol. (No, not the beer!) It worked perfectly, although I had to work the bristles for quite a long time until dark bits stopped coming out.
In future, any touching up I do will be with the Vallejo primer.
