Bpk 1/72 Boeing 737-100 plus lighting
peterairfix
Now I have finished my stearman time for another project this time its the BPK or big plane kits 737
The lightning kit is easy to install being plug in and play simple it say connect to any 12 on packet it goes to number 12 on the circuit board
And the kit
You should be safe with that one, no doors are likely to come off, anyway …
HI Peter should look great when done with them lights an may i ask where you bought the lighting kit with the pcb ?
chrisb
First job I have tried is separating the clear cockpit section as per instructions IMG_20240116_122029.jpg
But I made such a mess of cutting the new piece that I have reverted to the original piece IMG_20240116_122040.jpgIMG_20240116_122049.jpg
A tip I used in the past to cut plastic/perspex was to use a thin nylon chord. With a candle, wax the chord. Wind the chord around fingers of both hands and 'saw' the item to be cut. You get a loverly smooth cut.
Cabin lightining installed and fuselage warning beacon fittedIMG_20240119_151314.jpgIMG_20240119_145248.jpg
Fitted the cockpit section and windows IMG_20240119_151300.jpgIMG_20240119_145331.jpg
And Started wiring in currently Installed in the tail but will be fitted over centre wing. IMG_20240119_151314.jpg
Made more progress all lighting is fitted where it needs to go here's the mess of wiring and a video of what it does
Lufthansa? The military modeller/historian in me wants to ask if you’re going to finish it as D-ABCE Landshut — but that was a 737-200 :)
Almost finished I have fitted the engines and main landing gear and have the tyres ready to be fitted IMG_20240326_144219.jpgIMG_20240326_144223.jpg
Peter thats the strarboard side isnt it so it should be green hope you dont mind me pointing this out ?
chrisb
Finally managed to sort out the lighting now I just have to carefully get them back in the wingsIMG_20240411_174703.jpg
