Brushing rubber solution
Hi
I noticed an old discussion about having to clean brushes in cellusose thinners after applying Copydex or other rubber-based masking fluids. I thought I might share this little tip with everyone, but there are no guarantees involved, mind.
I find that Copydex and liquid moulding rubber pull off white bristle brushes after setting, leaving them perfectly re-usable. Black bristle brushes become clogged and are utterly wasted. However, I have only used the very cheap white bristle brushes available in cut price shops. I have not tried it with a decent brush and would not advise doing so.
Best wishes
Dickie
highlander67
\ said:
HiI noticed an old discussion about having to clean brushes in cellusose thinners after applying Copydex or other rubber-based masking fluids. I thought I might share this little tip with everyone, but there are no guarantees involved, mind.
Best wishes
Dickie
highlander67
BRILLIANT TIP MATE THANKS, i'M GOING TO DIP ALL MY BLACK BRUSHES IN WHITE PAINT TOMORROWW.
ANDY
Alternative - I use rubber tipped brushes
As an alternative, I use those soft rubber tipped brushes from Hobbycraft. They are so versatile and the dried masking fluid just rolls off after.
