Hi Guys,
I recently had purchased for me the Billing Boats HMS Victory set. Prior to this I have no wooden model making experience but have a reasonable amount of airfix kits under my belt - I'd like to think I've got a steady hand (and the patience to boot!). Very aware that you all probably think I'm mad starting off with a kit of this size/difficulty but hopefully i'll end up producing a kit to a respectable standard!
I've been using this forum as a reference, in an attempt to repay the internet stratosphere i'll post my build as often as I can; hopefully others will find some use in it!
So far I've just completed the decking on the lower decks - having never done any sort of decking before I'm really happy with the results. even though it won't be seen (much) I tried to do it as best i could so when im doing the decking on the upper decks i've got a bit of experience behind me. View attachment 65128
Let me know what you think! My main areas of concern are: the shade of the decking - i varied the shade of the deck to create a subtle uneven effect; is that accurate? also the thickness of the caulking - i used the rigging provided dyed and then i ran it through a blob of glue on my fingers.
View attachment 65129View attachment 65130
For those wondering, I'm using the Admiral Paints HMS Victory set and this colour was acheived by watering down the 'walnut' colour. I then applied it very gradually with a sponge.
Cheers all,
Sam
Cheers all,
Sam
