I'm trying to apply the camo pattern to my Tamiya German Steyr. I dont know if this type of camo has a particular name but I will describe this as a typical German camo style which appears to have finer lines applied over a main back colour.
Ive tried various combinations of thinner to paint ratios adjusted the pressure also the distance from the model that I spray from.
What appears to happen is that I cant seem to get a neat sharp line. The paint seems to spread and run if I get close then if I pull back then it is to wide. I have a 0.3 needle in my AB.
The only solution I can now think of is to apply a masking fluid to help achieve this but im not convinced this is the answer.
How do you guys go about this, help and advice please.
