I've been using it in one of my older Iwata airbrushes for a long time and it still works fine. Iwata are of course one of the manufacturers that does use resistant components made of materials like "teflon". I would be wary of some of the cheaper airbrushes as the may not.\ said:ive used it on mu iwata for the past year and had no problems and it strips any paint i put in it...but just be careful its nasty stuff alright
If it's a cheaper AB, it could have rubber 'o' ring type seals and yes, they could easily be damaged by Cellulose thinner.\ said:I was told to use cellulose to give my brush a good clean, but concerned about it melting any of the rubber seals, could this happenAdrian
I have watched several cleaning movies, but could you please tell me what you do in "I clean mine every session". For example, what is the max. time that you let your AB go from the first addition of paint to cleaning it? What are "the six parts dismantled"? - I can count four: nozzle, nozzle cover, nozzle tip cover (or whatever these two are called), needle. Do you use that tiny bottle brush every time to clean the passage between the nozzle area and the bottom of the cup?. And what does an "aggresive deep clean" involve?\ said:Actually Adrian if you get airbrush cleaning brushes this will give you as good a clean as necessary. Use Acrylic brush cleaner for Acrylics & Oil paint thinners for enamel.Softening up paint will not get rid of all the paint & without the brushes you will leave bits behind making matters worse. I clean mine every session & have never had to give an aggresive deep clean & I only use warm water that is for acrylics. All six parts dismantled & together in 4 mins.
Varnish, at least Vallejo, you need to make sure you do not cut corners & do it straight away.
Providing I follow all above & do it as soon as a session is complete it is perfect for the next session.
Steve, see the video on my post, page one, this is how I clean my airbrushes, also full size sprayguns with the relevant variations in stripping, (I used to spray for a Volkswagen specialist)\ said:Thanks very much. Its good to have the fine detail.I have been doing all the stages that you list but with one variation. It is interesting that you use water for all but the nozzle and its two guards, especially the way that you wash out the cup with warm running water. Using a lot of water, instead of several stages of small quantities of cleaner, is more likely to vigorously flush out any remaining paint in the airbrush itself, so I will do that from now on.
With more modelling I will be able to experiment with different proportions of thinners and air pressure (but I tend to use 20 PSI for general brushing).
Thanks will have a look tomorrow and see if I can solve to problem, thanks all for the great advice\ said:Threw together a 'how to' strip / check your airbrush seals and needle packing video so you can see how to check if it has the relevant seal type to safely spray cellulose (lacquer) thinner.Hope it's useful.
[video=youtube;g2aQtgzt4ZI]
