I am making a powerboat loosely based on the Fairey Christina 25 Powerboat based on Thunderbolt.
I was going to have 2 electric motors powering it like the real thing (real one was twin V8's) but was then decided that 2 24v motors & the battery pack to power them would be very heavy So i recently decided upon a single 2.5cc nitro engine
I dont have any pics of the boat yet or the parts to finish off the hull but i have a pic of the engine & 1 of the 2 24v electric Navy Compact motors it was going to have. that now cost £31.95 each (I got them when they were £25ish each)
They are listed as 6-9.6v but on a 9v battery they are slow & the battery went hot & died in about 5 mins.
The boat has a Heavy Duty prop shaft i think is 230mm long & M4 threadded
The engine cost me £50 & has not been run but i think it has a problem. When turning it over their are bubbles between the piston & the cylinder sleeve when the piston goes up & it bubbles from between the block, piston & sleeve when the piston goes down so i think i might have a compression failure at some point in the future but it will be funny to see but annoying to repair.
I have to somehow make a clutch bell or make something to fit on the clutch bell to connect it to the splined nut that goes onto the UCJ for the prop shaft.
I will have to make a custom exhaust & it will NOT have a silencer! & it will be a rather large boar because it lowers the pitch of the engine alot.
I was thinking of making a cover to fit over the air cooled head that would draw water up from under the boat, through the head & out of the exhaust using the exhaust to draw the water through like a vacuum but i think to be more reliable i should get the fan from a computer & use that for cooling since i made the cabin with an air scoop up both sides that were made to have pipes from them into the electric motors & then back out at 1 side.
I don't really have a clue about powerboats but i do know more about narrowboats & tugs ( I have a steam tug in the making also but having trouble finding a decent Mamod te1 boiler for it)
