Spoke to the Airbrush company that supplied my compressor as I suspected a problem. After switching off the pressure in the tank disappears after a few hours.
First advice they gave me, but not to solve my problem, was always empty the tank of pressure after use. Apparently it lessens the risk of corrosion in the tank & then less chance of this junk getting into the line feed.
Next was keep you compressor away from your area of airbrushing as much as possible. There are air intakes into the compressor & these have filters on them. If the filters get clogged with free paint spray they will affect the performance of the compressor. Associated was to check the filters now & then to ensure they are free. Pity the manufactures do not put that in their instructions.
My compressor is losing its pressure after switching off after about 6 hours. This may be due to corrosion or junk getting under the little plastic valves at the head of the piston pot. Just remove the plastic valve & clean (obviously after removing the piston head). There are in the model I have, AS Series, two of these plastic valves. If you do venture into the piston pot (only 4 screw allows entry) & remove the valves replace in the same position. Also replace the head in exactly the same relative position as dismantled. One valve is inlet the other I assume safety out let back into the piston pot. Get them the wrong way the compressor will do a St Vitus dance.
All this maintenance is dead easy as it is about the simplest machine I have ever seen.
