Hi all I seem to be having problems with my air compressor. Once it fills the tank to 57psi it used to shut off and you would hear what I would describe as a plinking noise which I presume is a solenoid cutting off the motor. You could then run an airbrush for a while before the motor would cut in again to replenish the tank. Over the last few days it has started coughing and spluttering once the tank is getting full and will eventually shut off no plinking noise is heard. As soon as you start using the airbrush it will immediately start up again. Obviously there's something wrong. Has anybody got an Ideas on how to fix this? I have emailed the firm I bought it off but have had no response so far. It's under the year in age so should be covered by the warranty. Anybody got a quick fix?
Vaughan
Vaughan
