Hi all,
I have recently purchased a compressor and airbrush set off of the Internet. It was only a cheap set as I've only just started out modelling (a non branded compressor + gravity fed airbrush).
The problem is the compressor will only allow me to adjust the working pressure between 0 - 24psi, although the instructions suggest it should allow regulation between 0 - 43psi.
I have returned the compressor to the supplier who checked it and said it was working fine so I had it back assuming hat I was doing something wrong.
As I'm new to airbrushing I'm not really sure what pressure I will realistically require. I guess the big question is will this compressor be sufficient or should I look to changing it for a more powerful model?
Thanks in advance,
Jay
Thanks in advance,
Jay
