Chaps, just a heads up, Iwata list a 0.2mm nozzle and cap (only) for their BR and CR A/B's. I enquired about what you do about the needle etc and they said "Use everything else from the 0.3mm kit". You would need to use MA or life colour but they say the A/B is okay with the set-up. So, If you fancy a try at even finer lines with the CR, it can be done quite cheaply (if you already have the 0.3mm kit).
Not sure I'm up for tha challenge, yet.
Rick.
BTW, I LOVE my CR 0.3mm, its like real love but without the hoovering...
Rick.
