deluxe model/pinflow does it stick photoetch to plastic ?
tanktrack
would the deluxe plastic magic using a pinflow glue photetch to plastic as it it is very precise with no bleed as my cyno use with tiny parts is a bit messy at times
I've never used Cyano to fix on P/E, I've had good success using Tamiya acrylic clear (X-22) fixed the P/E on and dries clear so you don't see it
The way I do it, is to put on a small amount of the X-22 where the P/E part is going to be fixed to, and brush the back of the part with it, let it go tacky for a minute, then pop on the part, then get some more X-22 on a fine brush, hold it next to the P/E part and let capillary action let it flow around the part, I've never had any parts fall off yet ..
