The weight penalty was a few hundred pounds and the speed gain I've read ,for a B-17,was a bit less than that,around 10 mph. The real gain was in cut production times. It's why later B-17s,with the exception of the horizontal stringers, have unprimed interiors. They simply weren't built to last as they didn't have to be. They would be lost or the war would be over before considerations like dissimilar metal corrosion would be a factor.
Bombers on all sides were never camouflaged for concealment in the air with the exception of underside colours designed to make them less visible from the ground,usually "black" on aircraft operating at night or the familiar blues,greys and blue/greens of daytime bombers.
Land based bombers were camouflaged for concealment on the ground. The RAF never altered the Dark Earth/ Dark Green scheme and Luftwaffe bombers and transports carried RLM 70/71 until its replacement (actually a substitution) by later colours in the 80s range. Maritime aircraft were camouflaged for concealment against the sea.
The B-17s were always going to be visible in the air,in daylight,no matter what colour they were painted. They didn't need concealing on the ground because noone was bombing their bases.
The RLM tried to cut production times by reducing the areas finished in a camouflage colour. A large scale trial using 50 aircraft was planned and Focke-Wulf were to carry this out at their Sorau factory. The Telex sent to Focke -Wulf and dated 30/6/44 said "in order to save labour and materials it is planned in future to omit camouflage paint on the underside of aircraft". A further communication asks "please advise us when the first aircraft in the finish as per instructions in previous correspondence will be delivered and how much labour time and materials will be saved by this measure" The bare metal was still primed with "the 119D primer of Messrs. Warnecke and Bohm". I've tried to look that up with no luck. I'm sure it is a clear laquer for metal presumably from group 19.
There is also a note on a Messerschmitt painting schedule for the Me262,dated 20/7/44, that only steel and timber components on the underside should be painted,presumably for the same reasons.
They never considered omitting the upper camouflage colours but then their airfields were being bombed and strafed on a regular basis.
As an aside,whilst looking for that laquer I found an instruction for the treatment of exhaust pipes common to all aircraft types. It makes for interesting reading.
"Exhaust pipes will be rubbed down with engine oil and painted with Kernick Black from G.Collardin,Cologne Braunsfeld"
I don't know what "Kernick Black" was,maybe something like the stuff my Grandma used on the fire place. I wonder if anyone bothered with this instruction once the war heated up,even if they could still get the product.
Steve (I will find that primer!)
