E shape BoB Dispersal pen
I am building an E shape BoB Dispersal pen. How big should it be? I have already started and will be posting photos soon cheers
According to this: http://en.wikipedia.org/wiki/Blast_pen
either 150 feet (46 m) or 190 feet (58 m) wide and 80 feet (24 m) front-to-back.
Although the pens were open to the sky the projecting sidewalls preserved the aircraft from lateral damage, with 12-inch (300 mm) thick, 9 feet (2.7 m) high concrete centres, and banked-up earth on either side, forming a roughly triangular section 18 feet (5.5 m) wide at their base.
Thanks. I am starting on their construction. The Actual base has taken shape as I carved out a base/outline out of balsa. I am going to mould the stuff on top of that. There is going to be an inner bunker as used in the E shape pens
Change of plans. I am making an Acrylic mould, designed out of Prodesktop 8. I will then vac-form molten plastic out of the mould.
Is this any good to you?
Some good stuff here, just accept the condition, it's free
http://archaeologydataservice.ac.uk/archives/archiveDownload?t=arch-882-1/dissemination/pdf/acarchae2-127600_1.pdf&Cheers
If you are ever near Bristol airport and have a tape measure handy......
