Finally took the plunge and got the kit.
So far I'e completed the watertight compartment ( Hope it's watertight but will test that later )
Cut the flooding holes in the lower hull
Checked out and temporarily mounted the motors.
Followed the instructions and fitted the drive shafts, thought they were ok.But.....
I came to position the rudders and rear hydroplanes and to do this correctly I needed to screw on the props. Catastrope, the props fouled the hull !!!!!.
So gauge out the drive shaft fairings ( made from milliput - bloody hard stuff )and reposition shaft guides. I've done the gauging out, the repositioning is to be done.
Thought someone ( George ) would like a good laugh !!!!
