Engine detailing
What are folk using for ignition wiring? Current project is 1/25 AMT kit (not very brilliant to say the least).
For 1/25 i've used the inner wires from old USB cables, they're thin enough for HT leads etc.
If you have an old Playstation controller then the wires from this seem to do ok for the battery (there's normally a black and red coloured wire)
For any brake pipes etc i've used fuse wire as it comes normally in three ampere rating thicknesses on a little card.
I've only made a couple of cars but this is what i found to be adequate for the job.
\ said:
For 1/25 i've used the inner wires from old USB cables, they're thin enough for HT leads etc.If you have an old Playstation controller then the wires from this seem to do ok for the battery (there's normally a black and red coloured wire)
I've been using the wire from old telephone wire, which can look a little thick, I never thought about using USB cable, many thanks for the tip Sir, will give it a try next time, as for brake lines all I use is the inner copper wire from normal wire...
Thanks for that. I shall look in the drawer that dare not be opened which appears to contain about several miles of old computer & telephone cable.
Bob...man in a snowdrift again
