To add fine line detail like the louvre vents shown in the picture.
Print the detail on a laser printer (photocopier might work but I haven't tried this). Reverse the image if it is 'handed' or contains text.
Prepare the area to receive the detail to it's final stage prior to varnish.
Trim the paper to a workable size, apply a thin coat of varnish to the image (printed face) and the area that is to take it.
Carefully place the paper face down on the surface (varnish to varnish), align it correctly and then use a roller or similar tool to remove any air bubbles that may be trapped.
When the varnish is dry soak the paper with water and very gently rub it away with a finger. Keep wetting the paper as it comes off and continue to rub until the detail is clearly visible. The paper may become transparent when wet so leave it to dry thoroughly before checking that all the paper has been rubbed away.
When rubbing the paper away it is important to be very gentle as it doesn't take much to go too far and rub away the detail as well.
So far I have only used this method on bare wood and white paint but it should work on almost any hard surface.
A trial on a piece of scrap is always advisable before trying it on your model.
Hope you find this helpful,
Scottie
/monthly_2005_01/57272b6d68457_linedetailtip.jpg.78859b0d322eca14a57d60c4adfc8c9e.jpg
Scottie
