Fixing metal to Resin?
As the title says I'm looking for the best method of fixing some metal parts onto resin, there not small parts and will make up a sub structure so needs to be tough. Would I be best of using an epoxy?
Here's an idea of the parts that need to be fixed in place, oh and a bonus point if anyone can tell what it is from :)
Thanks
Adrian
I would go epoxy but, if possible, pin it with paper clip wire or brass rod just to give it a tad more structural strength.
Epoxy should do the trick and Graham beat me to it, I would also be tempted to pin.
Looks like the underside of a Brakiri Avioki Cruiser.
Eeeeeeeeeeeepoxy! Sticks anything (and everything usually) screw fix will have small 2part tubes for 2-3quid
If you can't pin it would mitre mate stick it? It would be instant if you sprayed the activator but you'd only get 1 shot so get it right... :confused:
as said Adrian,epoxy,and real cannot see why your unable to pin it,
just have the pins flush with the base bit,and pre-drill before gluing, ;)
Hi Monica the metal fins are very thin can't even drill them with a 0.5 drill
oh well then,do see why,but the epoxy,once set should hold them,just put a few scratch
in the surface will give a bit more for the glue to take too, ;)
