Here is an interesting detail I've just discovered. Missed by most modellers including myself,until now. This applies only to metal propeller blades,many 190s had wooden blades....one more thing to check!
Translated order:
"When spraying previously unbalanced propeller blades care must be taken that a strip 30mm wide above the edge of the spinner is not sprayed (see sketch) so that the mark for blade adjustment remains visible. This area must be protected with masking tape before spraying....."
Here's the sketch:
And here is what it looked like on the real thing:
The devil is in the detail!
Translated order:
Here's the sketch:
