Gravity Feed Bottles
Hi - I have just been given an Iwata compressor and an Iwata BCR Airbrush. Have never used an airbrush before but have worked out how it all seems to work but I am missing a Gravity Feed bottle and Adaptor. Have checked in the ScaleModelShop but no luck. Where can I buy one from?
Thanks
Rod
Sorry - Have just realised that its a "SIPHON" feed bottle I need
Have a look on eBay, most of the airbrush shops sell them. I can recommend absolute airbrush, I've used them before.
Patrick
Thanks for the fast response. Having taken a look at the Airbrush Company site and looking into it a bit deeper, bearing in mind that I will be using the Airbrush for military models 1/35 scale, should I be looking at exchanging my IWATA BCR for a Gravity feed unit as, from what I can see, these use smaller amounts of paint?
Rod
I personally prefer a gravity fed airbrush, like you said you use much less paint, you can use as little as a few drops, this isn't really an advert :) but depending on budget the Revolution CR is probably the best if your going to be using things like Alclad, or the Neo CN if not
No sorry as everything I sell is new so I wouldn't be able to sell it on, you could put it on ebay or see if anyone one the forum would be interested.
